OK well I found some ones within the range specified by Logitech, but the other thing Ive just seen is the Voltage of the batteries, the...
Can I get something cleared up about these rechargeable batts? I bought one of these mice second hand and it came with no batteries, so a quick...
Sorry if the pics are a bit big, Ill sort out some smaller ones. Definately need to sort all the wires out. Thanks for the comments, Ill have...
Hi there, This is the first step into my casemodding. So far I've added a window and Thermaltake smartfan II with coolmod. Took some pics (and...
Addition:: So I have the plans and I know what I need but how do I mount all this. Could someone in UK who has the right tools make me a PCB or...
Well I will certainly keep you all up to date with the progress. Should have one of them put together in a week or so. Just need to decide on LED...
Im sorry acrimonious, my fault. I was mistaking the LED's and transistors for another optoisolator! That would have been an interesting curcuit...
Can I just ask, acrimonious, does this newest curcuit have the diodes in to protect from the relays, and doesnt there need to be a Vcc to power...
Does the curcuit for the off indicator LED really beed to be run through an optoisolator/transistor??
What size boards are we talking here?? 1x2 inch?? Any offeres on making one of these things to get me started??
Just a little ad-on: Im gonna use the relays in the curcuit. I like that reassuring sound of the click. And Id feel a lot safer using them.
Thanks a lot guzzler, that actually makes it easier to follow through... And thats a good idea, we should mass produce these things.. Thats sort...
I got it now. I almost fully understand the curcuit, now I just need to build it. I dont suppose anyone out there in the UK could supply me with...
I thought it was something like that, Id decided it was like a power-splitter.. One end you have the + and then you connect everything off that......
I managed to save the parts list so I can sort out the components. I didnt understand one bit of the curcuit, I thought that it would need to...
acrimonious could you also post a complete parts list for me, that would be excelent..
And whats the 'hidden digital power supply'?? Is this something to be concerned about..?
Wow. Thats brilliant. Thanks a lot acrimonious, Thats gonna save me a lot of time and space making these things. A bit of an explination of the...
Well Im gonna try and get all the stuff from my local Maplins so Ill take a look at which switches they have that look the part. Could I ask...
I dont think I need to worry about bounce if I get a decent switch do I? What if I put a small capacitor in line straight after the switch, so...
