ok... am ordering this.... instead of that 2k pot.. hope it's right : G1K MF Resistor 1k JM69A Min Pot Lin 1k may get a few diff...
i am looking for some.. where can i buy them in the uk using a solo card,... i need four of these: 2kOhm .... i can find i a 1k one.. but not 2k...
ok i've had a little look, after seeing the shape of the led's didn't realise b4, and your best of grinding some normal ones down
i have sum big arse hard drives like that in a big arsed old server.. it has a huge wacking big fan on the massive psu... what can i say it weighs...
isn't it a topless 1u, 2u or what ever u rack placed in a glass topped trolly/table
u can get the led's from maplins, they will b 3.3v or similar voltage ones, around teh 3v area
yes, i've got all that, i juts need summinc to use to control the fans
ok, thanx, dont need to do it yet, but just so hope u know what i mean.. that last circuit with fan shut down and led status... diff birghtnesses,...
yes i want silence so i can sleep :)
ok i've found out what kinda fan bus i wanna make, and am hopfully getting a wiring diagram and parts list.. and am gonna just use papst fans, .....
hi, i just found this, after being told about it, and am interested in making that last design u've made, wondering if it does work?? and if u...
hi, thanx for that site and the other thread, i want to be able to run 50 watt's each channel, so that would safe gaurd 2 120mm delta's, if i ever...
ok i wanna build a fan controller, i can soldoir.. but cant spell :), ok i want it like http://www.bit-tech.net/article/35/8 that, so i can push...
