Sounds a bit harsh, but if you're going to replace it anyway.. try giving it a good whack on the side (I've one that's been doing that for about a...
I've been beating the crap out of a Timex DATALINK for about 5 years now & it's never failed to function. Not sure about their USB loader for the...
Inexpensive stepper motors from MPJA
"Anyone know what Im looking for?" I don't. The linked item matches your criteria. Perhaps if the question was more concise, the response would...
I put "digital audio recorder" into a Yahoo search, this was the first of 5.8 million webpages.
ATX +12V, don't know what it powers, nor whether you can provide it from elsewhere.
Useful info.
Get the right size screws. Enlarging the holes will create other problems, the clearance for the heads of the upper two screws may not be...
Make a capacitor: two pieces of isulated wire kept at uniform distance from one another, more water = greater capacitance. This page gives the...
Mouser accepts a wide range of search criteria, better results if a category is selected.
Have a look at Mouser's part number 171-7425, see if it looks right. (would post a link, but oddly can't at the moment)
With most mirrors, the silver itself is thin enough to allow light through, once you've removed the backing paint. As long as the area around the...
Aircraft are grounded via a port on the outside of the fuselage. It's rare to get shocked while connecting them. Next time you're at an airfield,...
"up/down" Think what he was going for there was 'pulse train'. The 555 will generate a series of timed pulses which can be accurately controlled....
I've been parting-out printers for about two yrs, slowly approaching my goal of a fully automated Unimat. The steppers are more than strong enough...
I f you're not too concerned with looks (or are going to hack it up anyway): these guys have some good deals.
ATX Connector
Glowire says it'll run from 3 or 9 volts, & already has ready-rigged lengths.
Found this last year, seems to be on-topic.
How to open an iPod.
