Hi all, Im pretty new to access and VB programming and am having a few difficulties. First, I have wrote a VB for my access page that will...
Hello all, I am writing this thread to enquire whether anyone uses cooling fans made by Comair Rotron. If so, I would appreciate any comment...
Not sure if this is the right section, but does any one know of any free/cheap software that a data log information sent via a serial link (RS232...
Can some one help me, im running some tests on a thermistor, to basically see if I can heat one up to a required (internally heat it by putting...
Hi all, I work for a company that designs forced convection devices for the electronic cooling industry. I am currently working on a system...
Hi all, in need of some quick help. I have an old computer Im trying to setup, uses the ps/2 sockets for keyboard and mouse. On my main machine...
Hey guys, Just wonder, what can i use that is cheap and cheerful to clean all the dust from off my mainboard and cards???Dusty
Hi all, Ok, Im looking at putting 3 LEDs in the water of my fish tank, to light up the reef, etc. Now Although I have shrink tubed the legs...
Because of the silly prices many companies charge for shipping, I was wondering if any of you have a spare flip flop (not the ones you put on your...
I only need these two bits so am wondering if anyone would send me two pieces of Plexi Glass, 6mm or thick, with dimensions 40cm x 32.5cm at thier...
Obviouisly, if you have a bare wire left over from soldering two wires together (or LED legs in my caes) and you need to cover them, you use heat...
anyone know of a good online supply of small amount of plexi glass???
Can someone recomend a online supplier for a small quantity of Plexi glass
Hi all, Ok, I want to do a mod to an LCD screen i have, I want to stip it down and mount ONLY the very thin LCD glass its self to the screen...
can i hook these up to mains via a 12v tranformer??? Cold Cathodes
I have a 14v Power supply (not sure if its regulated) which is to drive a set of LEDs adding to 13.2V. Do I need to drop down the 0.8v or can...
Would it be possible to buy a Mac keyboard, strip it down and fit the stuff out my old wireless keyboard inside (the electronics..not the keys)...
Do Apple Mac Keyboards work on normal PC
Hi guys, I want to connect 80 LED's together and run them from the mains. What will be the best way of doing it, series or parallel?? and any...
Can someone help me find a transformer from RS compontent, that will step down 240V to 5V thanks Russ
