I was wondering if it's possible to take apart the 24-pin PSU connector and turn it into something more useful. Say another 12v rail and possibly...
R.I.P. Ordered the memory today for the 2nd board. Grabbed the inner frame and went out for a test fit with a mock hdd tower built and..... NO...
Well, since Benny isn't upset over it we will leave it at that. It's just a name. Since it's only a name, I think Keg-Server is worth holding...
I will give him credit for the kegputer but kegserver will stick around. Since you aren't posting here as an NVIDIA rep I won't bust your nuts for...
I'm updating my 2 forums and my website seperately. I do plan on putting vents in the top and a few fans inside. Once it's fully assembled. I'll...
Actually, you may want to search the forums here. I first used the term on August 31, 2006, in here as my first project after searching with...
PSU installed along with the mod to hold the hdd towers. To complete: install hdd towers and divider install mobos install hdds install...
Found what I was looking for. Pre-built and ready to install. Able to run on 3-12V DC power. Contacted the builder to see if it could be adapted...
I already thought about using the ones that emergency vehicles use but for my use I was hoping to build something unique. I've got an idea to...
Mechh69 I'm in the US and there are now strobing gumballs on the state cars. Headlights, tail lights and rear window lights are strobe too....
I was wondering if it's possible to create an alternating strobe light set (2 LED bulbs powered by USB or 4-pin molex). Something similar to what...
3 of the sides completed with perferrated sheets added inside the frame for added stability for the weigh of the parts to be added later. [IMG]
Progress is still being made slowly. Hours at work increased so time on the keg-server has decreased but none-the-less it will be finished....
Then don't click the link to see the photos. Only reason I put up the link is because I have friends that want to see the progress but don't want...
[IMG] [IMG] [IMG] [IMG] More images of the project are available by going to my site.
For the skeptics that aren't sure this project is going to make it til the end you may want to check out the link to the progress shots. As of...
Please take the time to vote in my poll so I can see if I should delve into a second project after this or not. Thinking the next project will...
I'm sure some are kinda interrested as to the progress of the Keg-Server. So I finally took a whole 30 minutes and threw together a quick page on...
If any of remember me talking years ago about turning an old beer keg into a computer then you'll remember that it never got past the sketchup and...
I am finally starting to get back to a mod that I started a couple years ago, the Keg-puter. With the release of the ATOM PC's, I have decided to...
