Oh man, I *love* those PLEDs but can't find anyone who stocks them - I don't suppose you have some left do you? Cheers Hellraiser...........>
Works now - I had a duff LCD :( Now time to get the rotary encoder fitted :) Cheers to ch424 for an ace mod, this is definitely quite snazzy...
Now this is weird. Still no display, but the backlight works - only problem is according to the spec for the display pin 16 is for backlight GND...
Hmmm, well that's a help, does much more when the PIC gets power :) No display/backlight yet, but will investigate further, at least it is picked...
Makes sense :) Will have another go the weekend if/when I get chance! I presume it won't break anything running the chip without half of the...
Don't suppose anyone can knock me up a PCB can they? For some reason my stripboard version doesn't work (beeper goes off when connected to USB,...
Just had a look at the schematic for this whilst figuring out a stripboard layout and I am confused - what are the BL+ and BL- pads for? Cheers...
To ensure you've not made an error with the programming, do the following:- Download and install Winpic from:...
Cheers mate, putting the order list together now - got my 18f2550's, LCD and mount, pity I'm working Sunday or I could get it all done then :)...
Awesome. I'm just about to build one of these (need to stripboard it cos I got no PCB gear), so a couple of questions:- 1) Has anybody knocked...
