clock and h-synch are pretty self explanetory, but I will leave this to the pros..... Plus, can you even solder something that small?
First of all, the gameboy screen IS an LCD..... secondly, if you can find a pinout for the bameboy and have über soldering skillz (those things...
If the monitor works, and the connections are right, I dont know what to say
You could have shorted two wires or something, causing the motherboard to become confused.... or the video card could just be dead. Is the video...
The problem with potentially using this is using the RGB outs. I wonder though if one could find a pinout for the LCD that has matching tags for...
I realize that DVI was not what you were talking about. I also realize that the pinouts for the LCD and DVI are different, but in the DVI-I...
Dvi? Wouldn't it be easiest and most logical to use a DVI-I conector, as it has RGB pins? This would tie together all of the R, G, and B pins on...
