Just use more digits! I'm creating 6 digits seperated by 2 colons. All you'd have to do is create another 6 or 8 digits (depending on whether you...
Not far off what I paid for the ultrabright blues from Component-shop.co.uk
Not quite sure this is the right forum for this, but anyway... A friend of mine had a bad DVI cable that would only let his 22" monitor run at...
Quick mini update... I've hit a problem. The LEDs are just too bright. Despite looking seriously cool... [img] ...they don't look so...
Thanks! Right here for LEDs
You might be better off with a PIC for this, I can't think how the latching can be done with a shift register.
Yeh I think it's going to come down to sanding the back of the perspex and diffusing with some glue on each LED or some thin paper. Each digit is...
I've decided to have a go at a copy of the sparkfun clock. Progress is slow (because money's tight!) but here's where it's at so far: [IMG]...
I especially love their photos of the "Official Site Opening". Looks like it was an incredibly exciting day for the one person sat at the PC...
Different sort of firewall in SP2, which is enabled at the time of install. SP1 has a basic firewall in the networking config, which is disabled...
Looks like a PSone LCD to me... there's a HowTo on the forums if you do a search! :)
Your DNS might not be set up correctly. The location for setting them varies between distros. On Debian, I know it's /etc/resolv.conf. I've not...
Are you gonna leave the sleeving ends like that, or going to do something with the ends? I always use heat-shrink sleeving to stop them fraying...
You can get standard IDE controller cards. Both IDE channels in my server packed up, so I bought one off Ebay. It's a happy-chappy now!
I'm confused... what's going to stop the water running down the channels and out of the side of the block? Other than that, very well made block!
