Sorry for that random comment i don't know where that came from
moo
:) Sounds like a good process. When I am actually awake i will try to work this out :) I will keep you informed.
It seems to work fine. However I now have got to add the following features: Alarm: Set an alarm and the alarm goes off when it reaches a...
I tried that and it didnt do anything. What I have just tried is to debounce the button with a delay. if(PORTB == 0b00000010)...
#include <pic.h> // Global Variables unsigned char Huns; unsigned char Tens, Units; unsigned char TensHours, UnitHours; unsigned char...
I am using the Hi-TECC C Compiler in MPLAB. As for matching the Display values, I have a switch-case statement in a dedicated function, which...
Hi guys. I am currently making a Digital Alarm Clock for my college project This is the circuit design so far. [IMG] I have the four...
I have put in the keypad routine i was given from my tutor etc. When i go to build the code, i get the following errors: Error[000] :...
Cool Thanks Turbokeu :) The alarm clock is coming on slowly but rapidly. I have got the multiplexing for the 4 &-Segment LED's and getting on...
[IMG] I want to do these features on my alarm Clock, will these different functions be possible?
#:) Thanks :) I have worked with Proteus on some examples i wqill keep giving it a shot, ill let you know how i get on :)
Sound advice, looks helpful, but complex. As I am new to this, I don’t know if I would be confident enough to do it like that. How does the...
Mike, ill answer your question's first :) The Displays are common cathode displays. Are column driver transistors essential and what...
Ok, this is the specification i want to follow for the project. Specification For my Alarm Clock the following components will be used to...
[IMG] This is the circuit i want to build up. I've built this design based on research. I just am unsure of the right way to go with this....
Hi and looking for help with alarm Clock Hi there guys, been reading through this topic and it is really inspiring. I am a 17 year old College...
