hey everyone, how would you go about making a wide radius bend in say, aluminium? maybe my rather weak paint-fu can explain. [IMG] any...
Hello, Is there a major structural difference between the two? I would probably be riveting them together.
[IMG] Think this'll fall apart quick? I was considering getting something like this lasercut on colored acrylic then gluing or using some type...
How do you wire up say a 3.5mm jack plug to the stuff from a molex? help would be appreciated
Hello bit-tech, Does anyone have any good tuts for learning AutoCAD? I want to learn some basics for CNC/Laser Cutting. Thanks a million
-read title- Thanks!
