Sounds great... Gimp is a really quality editing program once you get to use it... Nice to be back on these forums, as i haven't been here in...
why? all flash based mp3 players suck. hold nothing, and you still must tranfsfer everything. if you dont want an ipod, get an mp3 playing cd...
dont forget, if there was a decent wat to do 64bit encoding, the a64 would win. BTW, the athlon is a lot cheaper.
that case is incredibly overpriced. incredibly. my only input. :hehe:
open office .org!!!
i think your talking about fiberglass. fiberglass is what the y2k bug was made out of, and its the messy thing.
i love hdd's. more room for linux :rock:
now, i wouldn't exactly call linux lazy, simply more efficient. While xp must keep running processes to stay stable and functional, linux can...
i dont really like that trim at all. actually, i cant stand trim. try some double sided tape or screws/bolts.
ok, this isnt such a terrible problem. first of all, since rh9 is a dated distro, you might not see support for all of the advanced acpi stuff....
looks like a good start to a mod... that case is old skool :hehe: anyway, i wouldn't mind taking those old parts off your hands... pm me :D
for a case, you really do want something very solid and very basic. thats why i like the 1st one. the only mod already made is the x thing on...
in response in youre sig- star, have you seen fahrenheit 9/11?
i have the same mobo, its alright. keeps dying on me. anyway, have you checked your ram? that is most likely the cause. mine actually goes...
starting? :eyebrow: amd is my personal favorite. :rock: especially the athlon 64, those are crazy fast. :rock: i have an a-64 3200 running...
personally, i would like a warm pillow :D
thats good, it totally stumped me.
well, it looks like its gonna come down to your own choice. basically, if an athalon 64 3800 can be a bottleneck to an x800xt, your still in...
looks awesome. but, those bolts look kind of out of place to me kinda ugly. just my opinion. mod on :rock:
exactly, microsoft takes 3 months+ to patch it, while mozilla does it right away. shows you the efficiency of open source.
