Currently thinking of WRT-54GL, as i have one in my parent's place and like the stability and flexibility. Also, it is like a third off the price...
Do you have any products in particular that fits my needs? I am looking at 220-ish euro for an Apple Time Capsule. It does not seem bad...
I think you may be thinking of a Linksys, looks rather like a rocket base, and fits the characteristics. Don't think the "good" model ever made...
Hi, As i have recently moved to a new house without Wireless connection, and as my only machine is a Macbook pro running Boot Camp, i want to...
Nah. Really, i suck. Don't want to use too much time on that kind of stuff atm. Perhaps later though :)
Hm. Yeah, as i told you, if i had mad workmanship and skills and tools and stuff i have a good idea about how i like things to look, and good...
Hate to break it to you.. But you're wrong ;) There has been close to zero forethought going into the project. Notice how things changed all...
or what about an old CPU-cooler? My TT silent Viking II :naughty: [IMG]
yeah what i meant was that when you are watercooling ram it is a darn shame to do it halfway.. i do not think it will help your overclock just to...
i really never understood that one :wallbash: really looks nice polished and stuff, but its ugly when not imo.. and its no better than maze4,...
I dont know the brands. but as for Anti algae fluid i may be of help: instead of pet stores, try the places that sells chemicals. the danish word...
:thumb: :eeek: nice one! would fit your shiny rig nicely ;) how 'bout a blue sandwitch??
nice mouse :D I had a Keytronic keyboard once.. i think they are still alive, making OEM-stuff.. Your Poopy case sounds nice.. pictures?? :D
actually, no.. on the first page on extreme he mentions it using the ATX-plug ;) but i agree.. it is molex plugs on the unit for sure.. if they...
It sends a voltage down thrugh the dimm.. it gets stopped at the Mosfet. So ALL the modules get the vdimm this one sets. But as for the A64 i...
well i think it will be hard to make all the air hit the HS.. but the aero7 as mentioned has a blower: [IMG] they work quite well, provides a...
i'd say it like this: Copper, alu and silver are mostly great because of low thermal resistance or heat conductivity. The great thing is you get...
there is.. but it is not powerful at all... less than 1 amp for the most.. i dont think it is possible to start the pump from it, but it may be...
well.. it is not crap.. it works. you can place a cpu int the socket and make it run. you can put ram in the sockets and make them run.. but you...
You are SO walrus funny :D :hehe: furthermore the case looks great :thumb: what is that CPU?? celeron or P4?? it might very well be one...
