Alkaline AA's typically have about 2900mAh. Also, when my girlfriend got back from her trip she said the battery performed well. When she...
I actually found that you have to short one of the data lines to ground and then put the iPod in sleep mode and then it'll start charging. Pretty...
I just made one of these for my girlfriend (in a altoids gum tin no less), and when she tried to recharge her iPod it wouldn't work. Her DS can...
Do you know if that can be used without USB? Also, I found this, which looks promising. Basically all I need is something that can tell that...
I'm trying to set up a system that'll do stuff like turn on lights or wake up my computer or unlock the doors in my car, but I don't have the kind...
That would make working on my computer under my desk a heck of allot easer... Let's just say under there puts the nest in rat's nest... :D
I'm about to do the exact same thing with my mATX PSU. One thing you should look out for, my PSU used the case for grounding, three of the...
But do you keep your speakers inside your case right next to the hard drive? He's talking about the little tiny PC speaker in your case that goes...
The magnets inside the hard drive itself is bigger than any magnet could be in a PC speaker, unless you've got some gigantor powered 8" subwoofer...
The only problem should be the physical size of the diodes themselves. I'm no expert, but I'm pretty sure it should be fine, but if space is an...
Something like this? Digikey has these, exactly what you need right here. Soldering the chip to it might be a problem, though you can reflow...
I'm just going to bump this up to maybe stir up a little more interest in this topic. Plus the VESA connector isn't limited to ISA and PCI...
That's really cool, but I kinda wanted them to change speeds at which they blink. Maybe I could use a PIC to switch between a series of resisters...
I need some help from the electronics geniuses here. I'm building a case for my gf, and need help with one of the features. And instead of just...
Has anyone had any luck with purchasing one of these? I tried contacting noritake USA using the form but I haven't gotten a reply yet.
Acually (I think) only the last number is the firmware version. It's acually K6XXYZ. XX is the interface type (10 Async/SPI, 11 RS485/SPI, 12...
