Take the fan face up push the blade into the cage While you push in turn it down, you'll see a little pin behind the motor remove the clip: be...
there's alot of work to do, but I will end it someday. My last mod took me about 6 months to do, so I'm not in a hurry I forgot 1 pic I really...
Little update: Been working with the dremel today :) Cut this shape, do I have to explain how? I dont think so, anyway, it's always fun to...
Really nice work. If you need an advice, go with the 120mm fan, but maybe paint it :)
The Armor is not so cramped, its just fully loaded. For the new side of modding, I can only add that it became more an artwork then before. We...
I've planned to hide all the wire (as much as possible) I also want a full mirrored inside so only a couple of lights will be enough. I also...
I use to mod alot but after a while I was out of ideas and premade become too popular. This is the case I build about 3 years ago: [IMG] I...
Thx, I'll give it a try and tell you how it goes
The worse I've broke: I broke a complete P4 1.6 by overloading the PSU. Everything fried exept the floppy drive. I killed 2 PSU at the same...
I've done that a couple of years ago, but with a little difference. [IMG] [IMG] The use of rubber decrease the vibration, so it reduce the...
Was wondering if it was possible to bend a mirrored plexi?
At least it would work, so I don t have to buy another one, I had a couple of 5k left Thx
That mod look very very nice when you do it right, Here's mine: [IMG] [IMG] [IMG] [IMG]
I use it also in gaming, THe trackball is more precise and a lot faster :hehe:
What if I use a bigger pot to do this mod? Let say a 5k
