just ordered me a radeon 9600 pro to replace mine, bout 140 from ocs
Sorry, should have made myself clearer. I need a UK stockist, I already found plenty of US ones. Thanks though
Anyone know here I can buy, or how I can make a cable to run from a standard vga connector to 5 bnc connectors to run a monitor (or more...
Mostly just to show off really :blush: , but my computers usually doing something accessing tha hd, and that would provide a very random effect
I was planning on running the optoisolater into a 3.5mm jack on the back of the PC, and then using a lead to connect this to the table, so that it...
Thanks for all the help people, think i've half got it sussed. One more thing tho, is it possible to run the opto isolater thingy in parallel...
Not quite the standard endgraved window - but i need a bit of help from all you plexi gurus out there, and hopefully from the electronics experts...
We are planning on building a rig for LAN partys to store games on and run as a server, using a VIA eden board built into an alu tool box. Can we...
Anybody know where I can get a cheap 80mm holesaw? TIA Neil
Thanks a lot. Now i just gotta find someone with an 80mm holesaw i can borrow :-)
that wasn't exactly what i meant, but thanks for the attempt. If you cut the duct so that it has a flat edge, it will stick out from the bezel at...
Been thinking about doing this to the front of mine for ages, but how do you get it to match the curve on the front bezel? btw I also got the...
