In order to top this, your next build is going to have to cure cancer or something. Seriously, this is such an inspired and unique mod, and...
There are no words... :eeek: :jawdrop:
Super job, man :thumb: I don't know about you, but I have so much more fun working on a project like this that doesn't have to be perfect. The...
Have you tried a different keyboard yet? You could also try removing the default drivers and reinstalling them.
I have one of those. It's a clothes stand, like from a shop, but it's missing the pieces that stick out of the top and actually hold the clothes....
That's just as bad as zip ties and electrical tape. The reason velcro trumps all is that it easy be undone and then refastened in order to add...
"everything is static HTML" I missed that point, so I would agree that file/directory permissions are not likely the issue. I guess the...
Why would you assume one of those two possibilities? The two most likely ways a site can be defaced are insecure permissions and compromised...
The third picture shows the ends best. There are actually two hinges on each end, allowing for quite a range of movement. Honestly, though, I will...
Do you have access to maillog(or wherever postfix is logging)? I would expect more verbose output there than in the bounce message, plus any...
@ModMinded You may have something there. The arms could start off at a 90 degree angle and that would eliminate the kinking issue. I'm going to...
This is a fine time to start an SGA mod, what with the finale having just aired a couple of days ago. I'm a big Stargate fan and I like your...
@ModMinded, Cheapskate: The more I look at these the less I think they will work for routing hoses. I don't think it would be possible to...
While I'm not presently capable of building a proper robot, I like the idea. Anyone have any idea how I might get one of these to flex easily but...
Yeah, that could be cool. I was hoping to think of something that could take advantage of these in their existing form, rather than use individual...
I don't want to appear lazy, so I'm going to do a little brainstorming here myself. My first thought would be to use these for basically their...
I work for dedicated server host that uses dell poweredge servers, and with some models we get these extra bits we don't use. One thing that we...
I was having trouble finding the exact aluminum spacers I needed online(even in the US), but I ended up finding a good selection at my local mom...
That cover turned out really nice.
don't use white
