looks off to a good start, but you could definitly make that case alot smaller if a tiny case was you goal as well. But if it wasn't continue!...
I am looking for a good x16 PCI-e card to go into my new i7 rig. I recall seeing an ati card that was Crossfired, but it came in a single slot...
a little bit of the long way around might work. Make your CD drive on the desktop available to your network, then access the CDrom on the...
I just bought this laptop, and i am trying to connect the SPDIF output to my logitech Z setup(it has SPDIF coax connector). The problem is, it's...
repeaters would probably be the easiest, since all they require is minimal setup and external power.
newegg actually has this laptop on sale, with a $100 MIR. This makes it the same price as the above laptop, but with much better components. I...
i also have the older 720p model and the picture is outstanding! The colors are spot on and it has loads of connections on the back. Looks 10x...
pretty much, it's a pain the the arse. Sometimes adding something as small as a TV tuner or a new GFX card will trip the OS and cause a...
I opened a letter from my girlfriend this morning and it was a blank check, so i can buy a notebook for college. I am currently amassing parts for...
yeah, just sand it down with around 600 grit to get it smooth, the final coat will go on and hopefully dry as smooth as glass, so you won't have...
looks great! i can't wait to see the finished product. Lee
looks like a very promising project, I like the fram you have already built. But allow me to give you some advice one the fiberglassing. I've done...
I saved a ViewSonic VG730m from hitting the dumpster today. The monitor is in perfect condition and it works, but it constantly shuts off. It...
I've seen many people using u-channel with cuts in it to hide sharp edges. I have a P180 and I need to cut holes in my mobo tray for wire routing...
true, and they look alot cooler than your standard CD/DVD drive.
agreed. I've only found one kit so far, and all 3 blocks are separate. And it ships from the UK(i realize that really only a problem for me :D) Lee
awesome! Definitly makes it alto easier to show off your system, and upgrades will be a breeze too. Lee
doctor, get me 200cc of airDuster stat! I fear he may suffocate if we don't act quickly!
this seems like a cool idea if your just gonna be displaying the guitar on a wall mount or something. But once you fill the insides with all that...
thank you very much, this is exactly what i was looking for! Don't know how i never ran into it while searching, i've been scouring the net for...
