Just found these on youtube ! :jawdrop: <object width="425" height="355"><param name="movie"...
The display looks very different depending on many factors : ambient light level, viewing angle and the brightness of the auto-dimming feature....
Lastly, for now, a photo of one of the 2 hanging brackets for the clock. Made from mild steel, they are attached to the clock, using 2 of the 7...
Corners..... You can see in this photo how the corner sections of the aluminium profile are 'braced' together. Although no absolutley...
Right-hand side of the clock this time, also showing the LDR for auto display dimming & the 4 status LED's : Blue - Seconds 'beat' indicator,...
This picture shows the center two 4" high digits & 4 x 10mm colons of the 6-digit display, 'hours' or 'months', depending on which mode the clock...
This picture shows the left-hand side of the clock - the gaps in the profile at the corners are visible in this close-up photo.... however, they...
Plain 10mm x 10mm lengths of angled aluminium were firstly attached to all sides of the rear of main display PCB, forming a simple frame to which...
Aluminium Profile Pictures For 4" LED DCF-77 Wall Clock Firstly, a HUGE thanks to Chris (turbokeu), without who, it would never have been...
@ Turbokeu Thanks for the http://www.insideelectronics.net/projects/clock/ link - very interesting... something to work on. As a overdue beginner...
Thanks for the info Turbokeu - I think I'll give it a go with DCF77 then. The reception problem is a mystery... I have a Junghans MEGA1 DCF...
WOW - that is a wonderful range of lovely displays ! Thanks very much to g0th for the information re the ELEKTOR project on building a MSF...
Rugby MSF controlled LED clock project Hello all - my first post is this very interesting forum :-) I am endeavouring to build an MSF (UK) radio...
