Steveo: in that case, I would need a CF to SD adapter that has the chip which makes it ATA standard correct? That seems the easiest to do without...
Hi PC community! I am having an issue finding a reliable source to turn a memory card into a fixed drive. I am replacing an old 1.8 inch hard...
lysol: Yes, I have tried disabling it through the feature tab. I ran the sfc scan as it was disabled and it did find something but I could not...
Hi everyone, AFter going back to check if I can do anything with IE 10, under the windows feature turn on/off section, it did show IE 10 as an...
Hi everyone, I am trying to help with clearing out some affected programs after removing a virus, but I cannot uninstall Internet Explorer 10....
Ok, it only came in last week so i should be able to return it. Is getting it from amazon just as bad?
Hi everyone, My friend cracked part of her LCD screen and I was going to replace it for her. The laptop is a HP Pavilion DM4. When I...
Hi guys, Here is my update. I am suspecting the hard drive is dying for the reasons below: I ran linux off my flashdrive and the internet part...
For the upgrade, I completely wiped the drive before installing 7, I have done this many times with my builds and I made sure nothing would...
Phalanx: I watched the HDD light as it was in the shut down phase of the restart and it was not flashing rapidly. It was acting as if the hard...
Hi everyone, I am trying to diagnose my brothers computer and some of the programs are not running properly. So far I have tried Firefox,...
Alright, looks like the Coolermaster Hyper 212 is the winner for the cooler. As well as the Antec 300. Thanks for the feedback!
Hey everyone. I am in a small debate with deciding between getting a semi-low profile CPU cooler or a new case for a taller cooler. It is...
Alright cool, thanks for the advice!
I am sooner or later going to get Windows 7 Professional, but I cannot quite figure out which package to get. I am a system builder and...
Hold on, if the heatsink is compatibale with AM2 sockets, does it matter what version of the AMD CPU should be (Athlon, Sepron, Phenom, etc.)?...
I always went to the BIOS no matter what except one time when I wanted to make sure I was seeing 95C (was the first time it happened). I rotated...
Ok, I just bought the Sunbeam Cr-CCTF heatsink that has been given a lot of good reviews on. I wanted to lower my average temperature which has...
I am going to upgrade my present GeForce 8600 GT (which has been running for a little over 1.5 years now) to a GeForce GTX 260. Theres nothing...
well dust was the enemy in this case (and i mean a lot of dust). simple clean from the air compressor and now it works. thanks for the reference...
