If you have your OS disk and enough free external hard drive space, then I would suggest doing a complete wipe.....always more effective than any...
Windows media center in windows 7 requires no codec downloads like previous versions, however I still use VLC simply because I have used it for...
I would buy an external enclosure, and then backup some files you have then put it in a draw and forget about it. You never know when a hard...
I think firewall software should be more informative, it's no use a firewall program asking if you want "00445" for example blocked from gaining...
Sometimes it can be something as simple as the fuse in the plug, I have had this happen a few times. To this day I'm unsure as to what causes it...
1 point for Shift! ....although if I had a steering wheel the point would be going the other way.
So I got given a speaker system for my car, which I have installed fully in my car, I have had to disconnect the two back door speakers that were...
Granted plasma don't look as good in well lit areas and may be better than LED/LCD in a dimmed room, however they cost far more to run.... I...
I would recommend unplugging your battery whenever you are not using it, mine gives me less than 30 mins now so is pretty much useless :o
Never! ....adding blue ray to the will would double the cost of the console, which would mean loosing most of its customers. Blue ray might not...
Favorite game at the moment - COD WOW Despite loving the all the COD games, I feel like they are saturating the game ever so slightly, with a...
Evening all...bought a 125 varadero wright off for £250 about 2 1/2 months ago, it's finally ready for it's MOT (as far as I can see that is :s)...
Problem fixed....took out all the rollers and cleaned them. Thanks for the advice. Case closed.
Even some of the best antivirus programs fail to pick up common things like browser hijacking....although do to my computer's browser getting...
If I remember rightly..the main focus of windows xp mode is for businesses who have specially designed software that may have some incompatibility...
OS: windows XP Virus Program: Nod 32 So one of the computers in the office has decided to get infected with a virus :< ...I have tried...
Shaking the cartridge didn't work :s .....the printer is about 2 months old...wouldn't have thought it needed cleaning.
So I'm getting grief in the office, because the printer has decided it wants to leave a dirty black line down the left hand side of the page after...
I thought I maybe due to two screws missing at the back...so I took two from another PC in the hope it would correct it's self...no joy yet though.
Fixed it....there was no transfer activation though :s I needed to log in as the administrator...although you can install/uninstall all other...
