I'm going to apply this bended plexi method to my n64 cube (i'm redoing that project), many thanks for the inspiration :) One thing i'm curious...
The M7NCG 400 is your best bet for *currently* produced boards, although the M7NCG (non 400) is out there somewhere lurking in the shadows... It...
Just a thought - Most HTPC systems need one key thing: A TV tuner. I know you've got a PCI slot there, but do you intend on adding one? There are...
Yes its dead, but I have 4 other old mobo+cpu combos that I can submerge ;) I'm still thinking about doing it, just not right now.
Project is dead :( I already have two other projects lacking funds that I need to complete, so I decided to give up on this one and sell off...
Well, I looked at the option of a power supply from an external drive, but it looks like most of those are 2A or less of power :( I don't think...
Allright it looks like most SBC's don't even use the 12v rail :eek: If I submerge the system, it won't be running a 12v line for any reason as...
So the PSU is dead. I decided to disconnect the ATX plug since the SBC dosen't need it, and it ran fine once disconnected, but I messed up and the...
Small update: 1. I lost the auction, I posted that I had won it with 1.5 minutes to go and no other bidders (was a dutch auction) and some guy...
The power supply is stripped down (took a good hour, it had tons of tiny screws) and everything is ready to go except the cf->ide adapter, which...
Power supply arrived today, just waiting on the CF adapter which has shipped from china (im guessing later next week). I can start building the...
So the fate of this project is hanging by a thread... I ordered the CF to IDE adapter but i'm having reservations about submerging it. I'm...
Yeah it looks like I can grab an adapter on ebay for around $10 shipped, but they all come from hong kong so the wait will suck :( I did get...
This is a super low budget project (like all of my projects), so a 1GB CF card is out of the question. I'll probably either use a diskonchip...
Beleive it or not the hardware isn't really that old, socket 370 is still very much alive for the type of systems that use these ;) That board is...
Ah thanks for the info :) I'll seal them up really well!
====== So far ====== The plan is to take a single board computer (SBC), power supply, and some method of storage and dump them all into a tiny...
Allright i've posted the project summary, so if I update anything else it will be posted there instead of here or on the other forums ;)
Ok it's definately complete now, I went back and switched to properly sized, permanenelty hosted, and watermarked pictures. This is ready to be...
No thats a different thing. The 64DD was a nintendo product that played discs that were sort of like zip discs. It was scrapped before official...
