ah yes that was my board with the green caps. please ignore them and just get the standard types. they were some spares i had laying around....
sounds like great news. Looks like it will be a nice step forward in the design of the system im wondering going forward if the source code...
try both of the files listed on the link from this post. Post 261 if that doesnt work then please can you post what is happening. ie is it...
Vista 64 bit is working fine. Ihave had it running on my PC at home for months as far as i remember the latest .inf file from microchip works...
nice to hear that you got it working. its allways good to see pics of the finished product so once its finished post up some pics please Scorpia
Ok first of all the firmware was never designed for a 4x40 display. so you will most likely have issues with this display. also the cables need...
Thanks Erik i would still love the complete copy of the buttons code. Also a while back i got a copy of a modification to do a startup...
Thanks erik, no rush, im on a couple of other projects atm anyway.
Great to see you guys have got this working well. i also would love to get a copy of the code changes to make a 5 button version instead of the...
Just a little update for people. i have found that the latest CDC firmware from microship now has a driver (inf) file with official support for...
just found the link to the programmer i used. http://users.tpg.com.au/btkelly/jdm_b.htm but its not the correct socket for the 18f2550. so...
as far as i know you cant use the art2003 programmer because it ties up one of the pins the software needs to run the LCD. will have to get a...
not sure whats the go with up-files sending me to freindlyfiles. but there was some reports of there download software being spyware. a quick...
a couple of guesses. 1. did the pic verify when you programmed it? try a reprogram anyway. 2. is it asking for the driver file or just...
yeah, great work, are you making a custom PCB or vero board? if your making a Custom board dont forget to share. Scorpia
just having a quick look i would say shorten the cable from the chip to the lcd, it loooks like your using an old fdd cable or something. i...
can i ask why you would want to make the device HID compatable? from what i understand it would mean that you dont need to load the .inf file....
edit: deleted. double up of information. not needed.
yes i would love the modified code, i have allways wanted a welcome message so this would be great, PM if ya want. thanks Scorpia
my guess is the errors are your problem, you need to get it to not error on verify. maybe try another pic if you have one. otherwise try an...
