8800GT
run>> type "cmd">> format C: (or any other letter asigned to partition to be formatted)
Arena is great. In semi-final you should kill the guy with full armor and machine gun whereas you have only a knife and 4 grenades.
Download them from manufacturers site.
You can use trial version of True Image, it will certainly do the job.
Barracuda
trance
To crazydeep74: Because you didn't ask. :naughty:
I can't agree with you because RAID doesn't provide with decent protection from viruses.
True Image supports Vista and moreover it is pretty stable.
Daemon tools is great!!!
Why didn't you use backup software in order to protect the data?
It is very important to have a backup copy of your important data since the data you don't have at least two copies is the data you don't care...
As far as I remember the data in "My Documents" also would be lost after repair install, am I right?
Download driver for your sound card.
Zalman
Yeah.. that is so easy :) But I'd recommend you to browse the web because as far as I remember in some web shops it is a bit cheaper but...
For Vista 512 ram is not enough for sure.
True Image is compatible with Vista has simple interface and very reliable.
In Microsoft KB I read that it is highly not recommended to boot from usb drives. Unfortunately I forgot the reason why but it is for sure.
