Am i the only one who finds the images in articles too small in a lot of articles? The 365px wide pics just don't cut it imo - but i am liking the...
Well F***. It all started when i planned to build a HTPC. I thought it all out for months and finally landed on a suitable case for the...
Right. well i used to run dual monitors on my old 9800Pro and it worked wonderfully. Since i have my primary monitor on the right, and the...
Hey guys. I've been offered 260$AUD for my 9800pro w/ Silencer ATI1 (which runs 425/380 for general use, 430/390 - 440/400 for benching)....
Hi, Im having the dreaded "Driver not equal or less" (ndis.sys) BSOD on my server. I usually don't get this problem when surfing with one or...
hi, im having a problem with my MSI K8N Neo2. At first boot, the D-bracket just lit up 4 red leds indicating a faulty cpu. Great, i thought, and...
Edit: Got so frustrated with it, i just got rid of it all together! I <3 Zonealarm :p Ok, as it stands, i have one computer, my "server" which...
Would there be some way to make it that when you quote a post with images, it removes the [img] tags so when you reply it just has all the URLs?....
i just setup an AMD64rig and its showing up as 73*c at idle in the bios. i can't do anything becuase it just beeps at me @ "75*c" and shuts down...
Alrighty. My dad has asked me to start planning a New rig. Its to replace the P4 2.4B that we have, thats not cutting it anymore (gets pipped...
ok. so after a bit of surfing, i found a volt mod for the 9200: http://forums.extremeoverclocking.com/archive/index.php/t-114559.html now....
I know there has been things like this, and the answers have been "no", "no" and um "no" ok, so i was thinking, what if I was to bridge mod...
im having problems with a character LCD display (2x16 to be exact) i have been using it for months on end with no problems.... anyways, upon...
anyone seen this? http://www.xtremesystems.org/forums/showthread.php?s=&threadid=35875 :jawdrop: you can trick your DFI or Nf7-s to do...
well i got an nf7-s and a Zalman cnps7000a-cu today, but im having problems. it runs perfect at stock speeds (as it should) but when it comes to...
i thought i'd show you all what i've been up to lately :) a couple of months ago i rigged up a little fan bus to control the fans in my comp,...
Ok im a n00b at setting up LAN, but i need some help with getting past norton firewall (04). well i've got the family computer running the...
ok, so i decided to put more than 1.8v thru my cpu and overclock some more. So i had it set to 1.8v in the bios (the highest setting) and then...
Ever since we got xp on the family comp about a year ago, the film attachment for the scanner is useless. As there is no way to turn off the...
i just checked the price list for the computer shop near me. they usually only sell 2.8ghz+ northwoods and 3ghz+ prescott. Now they are selling...
