Thank you. I've found that some cables got loose and soldered them again but it still doesn't work... I'l try to connect them randomly as you...
Thank you! I think I've found the correct pinout order, because the 6th pin is connected to ground (to the metal plate) and the 3rd isn't. I'm...
Hello, I need some help with connecting a serial Synaptics touchpad to my computer. It is difficult to find out which is pin number 1 because the...
