I must say, I don't approve of a full wood rack case. I doubt it will support the weight of a 4U or even a 2U server without rails, even with...
Hi, and sorry for bumping this old thread ;) I was planning on using some (12 in total) VFD-tubes in an upcoming mod, but am a bit confused....
use tec7 to attach the plexi to the metal tec7 rocks :) (and it's a belgian product btw ;))
you could always de-solder them inside your PSU, sleeve them, and resolder them ;)
your gf is a real artist :o
use white decals ;)
have fun reading, but I suggest you do read it ;)
yes, it will, if you charge them like that regulary, but a couple of times won't kill them
http://www.sorobotics.org/smallbotics/PCB%20bug.htm press-n-peel, it's the same as ironing with glossy paper ;)
I found this here : And on my motherboard, the jr1 and jl1 jumpers are shorted (stock) So I guess I won't need to connect the return signal if...
to be normaly rude to you : STFU read my post, and the extract from the manual (so I did read the manual ^^ :sigh: ) I'll even quote so that...
I didn't know where to post this, so if it's posted in the wrong section, an admin / mod can move it ;) This is the pinlayout of the...
mod doesn't look bad, but the pics load very slowly PS, ALOA : 't west-vluts gaat er ook op achteruit, wa is nen onazelaar ? :p
about your idea with the touch sensor : it will be more complicated if you want the led to burn when you press the button, the beeper is in fact a...
No, you'd better go for a QT1080 then, it has AKS : from the datasheet, so if you'd looked it up yourself, you'd already know that ^^...
not really (in my case, not talking about DOS and Linux) I haven't set the power button action in my windows power management that, and the...
I still got a mobo with 2 busted RAM slots laying around here somewhere, but it still powers on I was going to use that to test if I could run...
:wallbash: :duh: told you I would mix'em up :p so, simple NPN (I know I can get a TIP31C in my local electronics shop) or optocoupler, what...
Something like this for an inverter ? (PNP trans, right ?) [img] only Q's that I have are : -output to ground or sense pin on motherboard...
That's what I don't want to do, it might break, and it's cheaper to ask someone that knwos this kind of stuff (and I sure hope he reads this forum...
