i am not sure what you mean by flying leads but this might help vga monitor connectors are also called male 15 pin d-subminiture (d-sub) for...
ok actually since an led is a diode it doesnt NEED a rectifier bridge to work and since most electricity is 50 or 60 hz u dont need a capacitor to...
you will need any resistor with at least 65 ohms of resistence so the closest ones they make will be a 68 ohm resistor. it only needs to...
thanks a bunch mate it finally works but do u mind telling me why. That protocol u told me to install is not installed on the other machines so...
what do i do in there
I just got a laptop running xin xp pro with integrated 802.11g and 10/100 lan. I can connect to the internet through my linksys wireless router...
ok thanks cpemma i will try that. the only problem was that the leds wouldnt turn off.
ok im trying to make a circuit that will turn many leds on and off with an input signal that is queit small. This circuit works fine but it only...
thanks for all the help guys u make this the best forum ever :D :D :D
wow those are quite expensive. i was thinking about just buying two of the 30-0-30 2 amp transformers i talked about above and wiring them in...
thanks for all the help guys but now that i have everything planned out i still need to find the parts. the main and most expensive thing will be...
well its actually exactly the same as usb [IMG] pin 1 is data that would probably be the best to use pin 3 is gnd pin4 is 5v pin 5 is clock...
does your motherboard or sound card have internal audio jacks on it if it does it will be really easy just look at the diagram that came with it...
ok that seems good. so i guess the graph i should look at is the one labeled safe area on the datasheet to see the power just the amp will draw....
so even though im only powering a 50watt sub i will need a 300w transformer this seems a little high and expensive. would using large caps on the...
i have been looking at an audio amp ic and i have been wondering how many amps it will pull. I want to use an lm3886 (spreadsheet here) with an 8...
ok i tried this circuit[IMG] and it didnt work. actually i dont have a lm741 yet so i was just using one op-amp from a quad op-amp chip. i set...
ok thanks for your help. a circuit that looks like this[IMG] should work then. do i need to worry about pins 1 and 5 at all or should it work...
ok so would i just use like an npn transistor and would that go into the inverting or non invterting side of the op-amp and i guess 6 volts would...
hey im trying to make headlights for my rc car and i need help getting the signal to the output. The signal is about 150mV and about 0.01mA max...
