actually she beleives that i have to set up the hardware and also, like 2 years ago he used to remove the PSU cable all the time and it ****ed the...
some manufacturer should make a 100% safe water cooling kit, and it's impossible to leak unless done intentionally. that'll boost their sales and...
hmm maybe i can make a lock door thingy, maybe with an old hard drive tray and some slot covers
yah, i use my window molding and it looks nice, but i dont think i can stick my plexi on with silicon due to the fact one part of my molding...
wtf nothing can be bigger than a ful tower PC75, make a tower urself, get some bricks, cement and ur on!
no im just saying, wut do you guys think bout it?
ok, i decided to stop grinding and sanding cuz every time i try, i **** up my cut. so im getting door edge molding. can i get it thin enough, yet...
I do now know wut i want! water cooling is way better but risky, thats why i didnt get it, since im new to this PC stuff. maybe in like 1-3 years...
wheover has a matrix orbital, here is my question, why does my text have black squares behind it?
When i grabbed my swiss army knife, the careless ****face i am... droped it, and wut luck! it landed right on my matrix orbital LCD and i plugged...
hey wait! do i have to mke plexi and under it mesh?!?!!
where can i where can i get body filler?
can someone gimme a more detailed way of putting the mesh using bolts?
so i can buy a mesh and split loom from auto zone?
this may sound newbish, but whats a bolt!
how do i stick the mesh? super glue? and answer my fan question plz
do you mean that all i gotta do is put the fan under and screw it?
can i get it in my size? or i have to cut?
ok where can i purchase a mesh and i didnt want the fans on top of eachther, i want em vertically alligned
hhehe ive tried it, my lil bro tells on me and i get into bigger trouble, AND its taken away longer
