lets see, counter strike 1, counter strike condition zero, and most importantly: counter strike source (Cs:s). love the games to death, source is...
well that is still in the process of decision. im thinking of a tall tower case with the vid cards hanging on the top. the kinds with the psu on...
well iv done some actual research finally and if come up with the idea: Mobo- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128337...
looking sweet love to internet indicators! keep up the good work!
o really, could you do a little tut on how to, im not into electronics and i would love to learn. EDIT: i mean the lighting part
with the green leds, it will look great with that desk you just built. i love your mods man!
i cant wait to spectate this build, nice design man
thank you all, im going to go with Frozen CPU
AND IT WORKS!!!!!!
THAT IS AMAZING!!!! IM GANNA TRY THAT RIGHT NOW!!! THX SO MUCH MAN THIS IS SOOOO COOOL
thanks for the heads up and good luck to you all
thank you very much, you dont evan know how much i appriciate this. i will order my materials in a few days.
question is where can i order the fittings/leads
sorry for such a late question but what kinda plywood is that and where did you get it>?
i need to know where to get the leads to connect the tubing two. also what do i use to install it (paste? idk) (i know plently of electronics its...
ok my idea is to make a resevior out of plexi. if you dont know what the cs logo is, then dont read this. i would like to make only the...
looks good, i like the idea that you got rid of the front design. keep up the good work man
did you forget spacers or are you just running off a table to try it out?
thx a ot man! good job
not to be mean or anything but same as he said.
