We have to make projekt before we gett our degrees. So i desaided to make a case mod. I'll have some consept art upp very soon. I'm going to...
There is backup units but they are kind of "not to be found". Can some one help me... i need to connect my 64 to my computer to gett the rom's...
I know this is not so common hear but i wan't to make them for my big brother. He has a toyota carina II (XL). I need some guid/blueprint how...
Can u make some cind of circut to have the fans running for a wile after the computer is shutdown. If u connect the gren and a blck wire on the...
I need to know how effective my water cooling system is before i make a block and putt it in my computer. Is there som formula to calkulate...
http://www.myplace.nu/mp3/ This is nice Work. check it out!!! sori nothing more to say.
http://www.myplace.nu/mp3/nokialcd.htm I want to put my on the computer To show temps atc. can it be done? how mutch dose it cost? i have...
I Have i question. Do you think a refridge compressor woud work to be used as a compressor for a airbrush. Around 4-5 bar max, and how mutsh is...
I know this has been up befor but heres what i have found so have a look http://www.pulju.net/shop/products.php?p=f8630a make i start the...
I ones found a web site that had a lot off stuff i think it was Finish(May be fom some other contry to). some thing i remeber from it was a rc...
A "roof matt" (a matt that you putt un roofs insted of steel and brick's..) or A yuoga matt (thicker then the "roof matt") the "roof matt"...
i neeed to gett from a scart plug (from my dvd) to separate Red, GREEN, BLUE and separate Hsynk,Vsynk so i can plug it to my monitor. A...
i need to know where to buy some coppar for a water block, and where to buy some plexi!! need some help to find it cheap Tarvitse tietää...
i have had a couple of ideas in the past i was wondering if some one has done them. I'm going to start to work on my cooling rig again, not shure...
I am thinking of buying a graphic card for about 200€. im from finland so from a store here woud be nice. witch shude investin a "SAPPHIRE R9600...
whit this case [IMG] a window mod. stealth the driver's. what else? i got some money and it's burning o hole in my pocket!!!
i was thinking off bying e pieter element off 51.6 w how effective is it
witch fan is better a Titan Alu fan http://www.web-jussi.com/only4pro/sivupohja.php?toiminto=tuotteet&esite=23643 or a DELTA FFB0812SHE...
i have a server on a linux apashi server and need to get a guest book to work we have the mysql skript but i we need to know how to call and write...
