i love invader zim too!. looking forward to see your mod. remember on irken technology everything is overkill. btw i have the dvd to.
Try this guide. http://www.mnpctech.com/Dremel.html
hoowaaaa, that looks justo great!, are you gonna make the other side to?, i must do that to mine :worried:
i love those big, white, chunky, old cases, they are like fresh clay that can be molded into anyting and they end up looking so original, i have...
Me2, to bad the project souds good.
OMFG! thats stunning!!!!..... congrats!, i don like wood, but... come on!, thats just to well done!, you rock! :rock: . i dont want to soud...
dude!, that`s some outstanding mod :rock: keep on modding! This shuldo go to mod projects IMO :baby: this deserves 5 !
Nice&cleen, I love it very very well done :rock: . --must get a shark case :worried: --
i just love CNC work :rock: ...
did you used primer?, IMO looks like you aplied too much paint on a single coat, also maybe a bad quality brand.
that aluminium pint looks great, can you give us a little more info?, i cant find any good aluminium or "chrome like" pint anyware, just crapy...
am i the only one who has used a propane torch for case modding??? :sigh:
That Staker is hugantamungussly BIG :o !!! That "landing" its a great idea, especialy for smaller cases, can you make some sort of gide? nice...
I`ll like to see a BIG TDX... it maybe some sort of marketing or publicity?... looks like a bad performer btw :worried: ...
whit that drill you can make a very nice Wblock, some "#rotor", just chek the procooling.com forums for #rotor
Franklin: you have some crazy skills with plexi :dremel: . cant wait to see more :rock:
2 80mm then, it would be nice to fit a 120mm fan, and fit the fan on top require some hard moding, and then remake the com-port (is that the...
quick question. tha Wavemaster has one 80mm fan for exhaust in the back and 2 for intake in front, is enoug room for a 120mm instead of the...
coolmiester: do you think its posible to fit a 120mm fan in the back of a Wavemaster?, replacing the original 80mm stok fan?. i was...
i want to see some LEDs on that flames, nice work! :rock:
