Well ive got lots of cuts and some scars from modding. I actually got a cut looking and examining a case at a local computer store :D So there is...
Yeah it whould:P Maby a little gathering of the locla modders had been cool too!
Yeah indeed :D That whould be utterly nice :D As i "live" in trondheim :)
Thats nice! What kinda audio equipment do you use! And have you tested how high (db) you can reach?
HOLY CRAP thats some nice computers
Your a god..... Is that the case for the watercooling only?
Nice, looks awsome.
Looks awsome m8. Great work so far. you actually given me some good ideas.
This looks promising. Will follow this one.
Looks damn nice. Cant wait to see it finished.
Primary rig is pci-e | second is agp | 3rd is onboard And im all the way pci-e so.
UPDATE 24 aug. Well have made some progress since last time i posted. Got 2 80mm AcRyan uv fans and a 50cm*50cm cheet of acryl allso...
go for 6600gt or 6800le, dont go for an mid-ranged Ati, cuz they are low on power and dosent perform as well as nvidias vid cards. Thats my...
looks sweet!!!!!
Looks good enough to me, but can i suggest that you go from built in vga to a seperate one, just get the price down on the mobo and get a vga going.
Witch motherboard is that? And the idea is great. Thinking about buying asus after all as well so. The project you have going looks freegin...
After painting the side door and the top of the case i discovered that the result today wasnt as pleasing as it was yesterday. the paint go a bit...
This looks awsome, great ideas. And the radiator placed in the bottom is just ace, dont have good enough words to suit this cleanlyness.
Looks good, the scetches looks ace(the ideas :D )
Well you wanted pictures, here they are: just added the second coat of silk black: [IMG] Just finished the other lot: [IMG] The top done:...
