mj007, have you started your pump up yet ? I'm curious how load are they and how well do they perform, (i.e. heat transfer, gpm) ?? Did you get...
Forgot to ask, but what kind of pump are you using ?? Has anyone used one of those 12v danger den pumps, i have a eihem (sp?) 1250 and its...
You could use some JB weld, its a 2 part epoxy putty that can be used to seal up holes in metal pipe. I havent used it my self but i hear its...
First off I got to say I am wicked jealous of your case, I want to get me one, but I just modded my lian-li pc60 case......dam. I cant wait for...
I love this stuff, and i want to do something like this on my lian li, but i dont know where you can find blue uv reactive acrylic in canada. Does...
Hey why dont you mount the Dvd drive in its mouth, then you could load the cd's between his teeth ?? :jawdrop: Just a suggestion.
OMG Modders unite for we have a new leader !!! Hail the king :clap: Hail the king :clap: G-gnome, you have thrown the gauntlet down, you...
Can someone say.....SLAM....put that it your pipe and smoke it!! Well done mrhaz, i enjoyed the review very much, maybe this is why we all use...
I got it !! Well i would of loved to see a barton, but i really dont think it is. Yes its an asus board and i bet you its a .............. Athlon...
