Mine has always showed packets as opposed to bytes. What's everyone elses (English XP) display?
yes the bat file worked. thanks for the help. after i edited it i gave it out to all my co-workers and since then no need to double click after...
correct... 2k/nt network. thanks for the info, tomorrow i'll give it a try.
received file and in the process of editing, thanks :)
sure. could you send the file to acdien2@uky.edu? thanks for your help :D
i contacted admin and yes i have all access rights needed, and like i said i can connect after i double click on the mapped link. it's just the...
I hate to do this but I need any advice on this asap, and figured I'd get more views in general as opposed to network and communication itself....
My work machine is mapped to at least 15 network drives. Whenever I restart my computer, all but three or four of these drives reconnect. Yet...
Lately I have been monitoring which applications I use and for the past 4 days I stopped using morpheus. Today I fire up morpheus and a couple...
Take a look at this: [IMG] I'm not quite sure where this data is going. I'm running @guard firewall and have been checking the outbound...
This may help... I posted a similar question a few days ago. Here's the thread... http://forums.bit-tech.net/showthread.php?threadid=4015...
Since the post I've d/ed Redhat 7.2 from their site. I'd like to set up a ircserver like Darragon mentioned. Any suggestions for software or is...
Here's the deal: I have a p166 just sitting around that isn't being used. I know nothing about linux or its various distributions, but I've...
