Is it possible? My friend said that modding my wireless keyboard isn't possible. I mean is it possible? If it is would it be a lot harder than a...
OK well I need something for my Lian Li. You Know the Little connectors on the front panel that allows it to pop right off really easily well i...
I want to turn these into just some blacklights for my room. These were the ones for computer cases from pcmods.com and i tried to return but its...
Hey what have u got to lose by putting on a shim i mean it doesn't hurt spending 5 bux now and not having to replace ur proc am i right or am i...
Hey its been awhile since i posted so i thought WTH. Anyway I had the exact same problem here and i posted and i would like to thank flix-the-cat...
WHAT there are such a thing? There is a Metal Gear Solid PC? What about Metal Gear Solid 2 is that coming for PC also? I mean If there is a ps...
Well i don't know much about the Starcraft 2 thing except that it was a sweet A$$ game!!! All i really know about is WARCRAFT III ships June 25!!!...
Well i took the Crappy Lapping job off my Visiontek Geforce 4 TI 4600. And Applied some Artic silver 3 smoothed it out with a card u know the...
check www.newegg.com
IF u ask me....DELTAs aren't bad. They are a little noisy but its like white noise its not like a baby crying or something. Its more like a...
Anyway I finally started on Operation: "Punished". I have 4 new blow holes in the back of my Lian Li PC-61 (3 40mm, 1 80mm). I also finally worked...
Hey Thanks for ur help, I added a blowhole that dropped my system temp to 26 degrees at full load and my proc down to 41 degrees I am still adding...
Well I am about to solder on a new Red LED to my Lian Li my friend unsoldered the other one and kept it because it was blue. I was going to...
I have an Alpha Pal 8045u w/ Delta 80mm 80cfm Fan on there and i just finished installing Windows 2000 and i was looking at my temps and my proc...
I was gonna get one of these for my Alpha Pal 8045...currently I have a Delta 80mm 80cfm Fan. I was gonna get this adapter and put a 120mm 190cfm...
While on the subject think it would be possible to cut the original pcmods knobs??? I mean i have black ones and they are purty enough and i was...
DUAL BOOTS MAN DUAL BOOTS!!! I mean u can have ur Windows 98 SE for all the games just make sure u have all the latest updates for all ur isht (so...
i was thinking about that..wasn't sure if Vinyl Dye would be the ticket or some of that stained glass paint crap that still allows the adapter to...
