Bummer, it won't work, capture software only captures whats on screen, my document is too long, so when in word you must scroll down to see the...
Never thought of that, will give it a go, cheers clever ****:D
Does anyone know of a free programme for converting word documents to jpeg, i have created a word document of my shifts rota at work and need to...
Yeah thats what i thought going off ebuyers page regarding the 22inch, confusing thing is though the 20inch is the same spec is it not, or am i...
Thanks again mate, cheers.:thumb::thumb:
Something thats just come to mind, does that cable reduce picture quality at all.
Ok, thanks alot,:D
Does such a thing exsist, things have come on leaps and bounds since i was last into this type of thing.
Just a quicky, is it possible to connect an xbox 360 to this monitor or do i need the model with the TV tuner,...
I'm a bit like this, having said that i've always been a bit of a night person, nearly always had night shift jobs until lately, now i do early...
No, right now it is super silent, but as soon as i run scanning software or view large pictures that take a little time to load the fans kick in...
Ok, just repalced the thermal paste and it's still doing it, anymore ideas.
Almost 2 years ago i made the mistake of buying an HP media center PC,yes i know i should have built my own but at the time i was loosing interest...
Ok, thanks alot :D
Ok, but what do i buy 8x or 16x, dual layer, or none dual layer, ones with dye or ones without, whats the best to buy, i don't want to buy discs...
Yeah but what do i buy, the choice seems endless, 8x 16x dual layer, i don't have a clue.
Hi all, Need some help as usual, I need to buy some DVD discs, but what on earth do i buy, i went to my local shop and the choice is so...
Ok guys not Pc related but hope someone can help me out (got two questions) Q1 Can someone tell me how i wire the below switch, the switch...
Well i have to say, what an excellent explanation, It now works 100%, Thankyou very much, really appreciate the help.
Ok, done everything suggested and still nothing, there is something however that i have just come across, the ip address and subnet on my modem is...
