Driving LEDs from Mains Voltage First of all, usual warnings about lethal voltages, need for good insulation, etc. That said, the simple way...
It is fairly simple, but you need to watch your voltage levels. If your whole system is running at 3.3V, then it's easy; if you want to run the...
I have built a MSF decoder using a ByPic micro and a Symtrik receiver module. The Symtrik module (search on Ebay) is cheap and effective, but...
