Cheers all, maybe I will stick with the TJ07 and see how it fares with the 680. Did a couple of searches RE 3570k vs 3770k and I reckon the i7 is...
Fair enough, 790i proved to be a bad choice! Here's hoping the Z77 is more reliable!
Ok, thanks for the replies. I looked into memory a bit further and noticed the correlation between speed and voltage. Is there a reason to...
Happy new Year all, To celebrate the new year I'm contemplating a significant system upgrade. It's almost a complete re-build, but I can re-use...
Hi All, Recently upgraded my system to give Nvidia Surround a go - System Specs: ASUS STRIKER II EXTREME 790i Intel Q6600 Quadcore CPU (@...
Can I ask what motherboard you were using?
Downloaded thanks, and is presenting me with loads of information, not all of which I understand right now, but will have a look through and see...
Thanks guys, lots of suggestions there. Machine is even worse today than it was yesterday, and I'm now having regular problems with Windows...
Thanks for your thoughts AstralWanderer, will let you know if I see any difference over next few weeks. Lankuzo, I have not. In fact I've not...
I’ll remove AVG from start-up for the next couple of weeks and see if that alleviates the start-up problem. Below is the current airflow...
Downloading 270.61 now. I agree 50C seems a bit on the high side for idle, however others do report high temps from these:...
I'll look into the utilities noted and install something to track temps next time I game. I don't game that regularly however that said I have...
System software specs as promised, highlighting bits that may be of more interest. Not sure how to check forceware version, but it might be...
Thanks for your input. I kept a close eye on my CPU Temps (using CoreTemps + others), especially under early overclocking, and they never went...
Thanks for your contribution. I'm hoping that not all 775's had this problem, maybe we were both unlucky? Would be interesting to know if all...
Hi All, I used to be an active member on the old custom PC forums (long time ago), but this is my first post since the move! I built a...
