oh okay. Thanks
Hey guys. I was trying to reinstall my video drivers for my 5870. I used ati uninstall utility to remove my drivers. Upon restart window 7...
Well I do not know what hardware acceleration is and what it does?? Is it really that important and what are the benefits and drawbacks??
well here is a link to my mini dump files. Please have a look. http://www.zshare.net/download/781440579ced2685/...
Hey guys I am having a different problem. When I try to watch youtube or hulu video I get a BSOD. I have a radeon 5870 and I can play any game...
I have solved my problem. My motherboard was bent in the middle and so was the riser which caused a short. I have replaced the riser and...
So here is an update. I just talked to the computer repair guy and he said all my part are working fine......outside the case.......wtf??? Is...
For the motherboard I have had it RMA by Asus and they told me nothing is wrong with my motherboard. For the GPU that I am pretty sure is fine...
The PSU fan spins less than a second and nothing turns on. What can be causing shortening and what do you mean by that?? I have the mobo on the...
Here is an update. My computer today worked for like 6 hours and had normal post. When you turn on your computer I get the short beep and things...
also my cpu has the megahalem cpu cooler and stays around 35-38C. So temps are fine.
Hey guys I have built my second computer. It was working fine for three months and now I am running into problems. My computer turned off...
