Got my Aego Ms 4 years ago for Christmas. Still using them - and loving them - to this day. You will not regret it! But whatever you do, steer...
Cleaned and reseated my Dell and IBM laptops without any hitches. Tried to do the same to a more consumer-orientated Samsung and it was the most...
Parge, quiet sleeve bearing fans will cost quite a bit more than their ball bearing breathren. I still recommend Nexus D12SL-12 120mm fans, which...
I have a 1TB hard disk that has all my most irreplaceable files on it, which spends most of its time off and stored safely. I gave up on optical...
Sometimes memory need 1.65V but the BIOS will be automatically set to something lower like 1.5V. Try checking that and manually changing the...
Since you don't know what you'll be programming for, I would recommend Python. It's easy to get started, it's fun, it's well documented, and it...
Leave them as separate drives, and backup to other drives or mediums. RAID is not backup.
I can only recommend RAID if the data is access critical. You're better off keeping it to 1 HDD and backing it up elsewhere.
+2 to Zalman MFC-1. Very sleek brushed aluminium look.
With common sense, a little caution by handling around the edges, and not wearing synthetic clothing it's difficult to kill components. I like to...
I own a pair of Sony MDR-V6s, and it's very good pair of bassy cans that isn't too bloated. Apparently its full potential is only realised with an...
I believe the old 1200 RPM S-Flex fans used to whine but is fixed now. Which Noctuas btw? Some of them have odd fin arrangements that give them...
With dual- and quad- cores the area required is going to be bigger than the P3/Athlon XP days. But yes there's really no need to spread the paste...
Socket 1156 is a dead end when Sandy Bridge arrives. I'd say hold out until then before you upgrade to a new motherboard socket. Your current...
Definitely build it for silence. Since you're going to be transcoding I would use the Q6600 at stock with SpeedStep enabled on the P35...
Maybe in other components, but with hard drives - especially ones destined just to store data - I would always buy whatever's cheapest. Each brand...
For direct touch heatpipes, take a look at this article:...
I had a quick look on AMD chipsets too. The 800 series of chipsets are a solid buy, and should be compatible with the initial wave of AMD's new...
I'm a firm believer of single slot upgrades; you either buy 2 and SLI/Crossfire it straight away or you upgrade down a single card route. I'd say...
I'd recommend buying a DD-WRT compatible router, as you can adjust the transmit power and the interface is very smooth as DD-WRT requires a...
