I have a tk smart fan and a usb cable (2.0) that i want to mod into a USB fan for my laptop (P4 3.0Ghz, 1GB, 7200RPM drive...) which gets very...
You can use a BASIC Stamp Kit to control lights and stuff its also very easy to program with it... look at www.parallax.com
Ive thought about this for some of the doctors/medical billers i help... they need ways to make sure that the system cannot be used by anyone but...
I think that there needs to be the fallowing: 1) sources to get the parts 2) what different features/specs are for on different parts (Just the...
I dont think so.... I wanted an extra one to play with before i worked on my case's mods but i was unable to find another one... you can use sheet...
Thermite, if i remember correctly thats a mineral and if so i have lots of it... (White Powdery Mineral... Falls apart easy....)
Lol yah i know i dont use them anymore... i use velcrow ones...
My self i dont need one but i know people that sometimes like to build there systems but dont know anything really... I really need to write...
Thats a good idea for the PSU... warrmr your cable really is slow if i took more than a second to load them pics, im on a satellite connection...
Looks GREAT!... Also i have to say that it looks like a bomb with a fan on it, but it does look really good.
Ok this happend back in like 2002, i was building my first computer right well i like to trinker with things so about 3 months after i had...
Zidane, i see no reason that you wouldnt be able to make the USB cable another 15 or even another 20 meters as long as you use cat5 cable, however...
Yah... im working on a design like that, my only problem is that my PSU would be on top of my PCI slots, and if i ever needed to add a card that...
:dremel: :dremel: I need help... I will be building a wood case this summer in my grandfathers shop (He built cabinets for like 40 years so he...
Where can i get spray carbon? i thought about paint.. that old stuff with lead but i dont have any...
OK thx i thought it would be ok as my monitor is almost 6 feet away... My idea was to use aluminum with a high lead content because my grandfather...
:dremel: Im building a Wood Case out of 3/4 Hard Wood (Oak), and this has been on my mind for some time... I want to know what kind of EMI...
