I hope you realize that on the firewire cable thing, you have to press down both sides in order to disconnect it from the ipod, it doesn't just...
Its 100% safe if you're not an idiot and check everything the first time around, and make sure everything is properly fitted and etc.
Good point.. Well what I ment was have the fan hole be the comet itself, and have flames shooting off to the top right of the side panel. I'm not...
So I've built myself an entertainment computer, hooked up to my tv to use to play movies, emulators, and maybe music. I want to bondo the whole...
Whoops :duh: ... Figured I would post it here since my last 2 threads were in here, and this really relates to those threads. Mods, feel free to...
It's been running at a steady 50C ever since I finished modding a mounting bracket for an MCW50 to mount on my 6800GTOC. Last night I overclocked...
Well come on, I hate to sound like an ass, but that's pretty bad. He could have posted the original window in his post, and said that he was...
Thanks for the kind words. It is running fine now, low high 40's low 50's, even under full load (during hl2). I do plan to overclock it, although...
That deffinitly was not a problem. I made sure I did not put too much on, t'was a very thin layer.
Alright guys, update time. I took the waterblock off, and re-set it with new thermal paste and such, and fired her up. It is now at a steady 51...
It's only warm to the touch, not burning hot. :confused:
Wow, your version sucks compared to the real one. If you're going to steal someone else's design, try and make it look decent at least.
I made a thread before about modding an MC350 onto a 6800GT, well after much planning and doing, I finally finished it. I put ramsinks on all of...
It's already OC'ed. Like I said, it is not a normal 6800GT, its a 6800GTOC. Speeds are; 371 core, 1002 memory. If this watercooling thing works, I...
I will not be o/c'ing though. Actually, the card is already overclocked (according to the box), I got some special overclocked version of the 6800gt.
Thanks everyone! Will start work on this sometime in the next week... you guys rock :rock:
Only thing I don't know is...how do you attach RAMSink's onto the ram?? Some sort of glue?
But the heatsink that is on there right now (stock, air) is gigantic. It has dual fans, heatpipes, all copper, etc. The waterblock is about 1/3...
Would the MCW50 have enough cooling to cool my 6800GT OC? The surface area on the waterblock is the same size as the GPU on my 6800, so I figured...
Damn thats ghetto. :hip: :D
