Thanks for the input. PS : my initial intention was to make the design available to everyone for free so stealing something free is kind of...
I guess patenting my design is out 200$ is double what I?m going to spend on making the case My design is great but I don?t have 200$ (8k in...
I beg to differ I worked on a design invested time and effort in it I feel has potential to stand out in a crowd of other design so if money is...
Not a case mod A custom case Complete new case from scratch with simple mechanical features not used in computer cases as far as I know...
Couple of reasons for the above questions - want to share my design wit ppl as I got inspiration mostly from ppl who shared their design 4 free...
A couple of questions? - Is it possible to patent / protect a custom case design? - I want to share the design with people for free but...
. tis may help ATX Motherboard + Motherboard Tray + Mounting Screws + Rear IO Panel .
could u tell me how to draw a sphere ?
plz update front page link updated file with a few minor corrections ATX Motherboard + Motherboard Tray + Mounting Screws + Rear IO Panel
though i own a jigsaw the way i cut a hole in my side panel was rather crude and simple take the side panel draw ur desired design to be cut...
dont need tht i already made some thing better my issue waz wit the a spinning 120 mm fan causing interference with a HDD & would using a metal...
design constraints forcing me to keep it flat against the rack maybe give it another 10 mm gap max would that suffice or should i put a...
4 HDD?s stack cooling with 120mm fan, possible problems?. Small question ? Will placing a 120mm fan flush against a rack of 4 HDD?s (on the...
ATX Motherboard + Motherboard Tray + Mounting Screws + Rear IO Panel ATX Motherboard + Motherboard Tray + Mounting Screws + Rear IO Panel I...
i would suggest u take a soft cotton cloth (no static) moisten it slightly and happly wipe away jus a couple of things to remember -switch...
very neat design one of the few good custom cases i've seen in a long time gonna be following this one :thumb: hope to see the...
