Its £10 pounds at the moment item number 6856341939. I had intended to use it just for displaying visualisations and the like, so it wouldn't...
Putting white plexi behind kind of defeats the idea of a transparent window.
I've just been looking on Ebay and someone is selling an In Focus 5000CX Projector. It is supposed to be a PC projecor that sits on an overhead...
Yes I have tried searching both the chip numbers and the serial number on the label, nothing of any use appeared.
Hi I have an old laptop touchpad that I was hoping to mount into a keyboard wrist rest. Does anybody know if it can be connected to the ps2 mouse...
Hi have a look at Machine Mart they do three similar cross travel vice that allow movement in two horizontal planes so combining accurate...
You can chrome plate alloy bike engine cases, excesive heat used to make it crack though.
