cool, I'll ditch the laptop screen idea. I've read through the post you mentioned, now the guide is up I'll have a look through it :hip:
that's sweeeeet! I like the idea behind it to. Do you think it could double as a fat heatsink? couple of large fans inside, what looks like a mass...
Thinking back I remember OpenGL doesn't work using multiple moniotors (AGP+PCI) at least under windows I think it does in linux. Look forward...
I read in the micromart some time back = 10 things you can do with your old 486. Yep one of those was to create an in-car mp3 player. THis was...
I would have thought the vga card would be doing the processing and only send the signal to the screen?
don't think I'll be getting anything from ebuyer, doesn't exactly get the best reviews. I've bought from dabs and can't remember having any troubles
bit steep, was that a standard ATX case? would be a bitch matching the CD/DVD drives aswell though ishiii, what parts ru thinking of chroming?
yeah good idea whoever thought of it first...don't know the first thing about electronics so this kind of thing is inspirational as it's simple...
great idea you've had! do you think it would be possible to wire more than one of these in to one vid card? with a bit of fiber glass moulding...
yeah definately see the G4 in that...I like the idea of an arm chair computer...With the right chair and pc parts everything could go in one are,...
I was fitting an Aerogate II in my shuttle and noticed that by removing a few parts like the fan / exhaust and with the right bits this could be...
yeah go with the smaller one it'll look good with a lick of paint...Are you planning on using the HUGE fan on the front :dremel:
Cool I guessed as much and now set it to 3/3 I've dropped the voltage and FSB from it running at 2475mhz || 12.5 || 1.9v @ 60c to a much...
you could check these ones out if you haven't already http://www.matrixorbital.com/pages/products.asp?CatID=3
nice 1, I found and enabled the CPU Interface but was unable to see anything to turn the divider off, unless it's "CPU FSB/DRAM ratio" :confused:...
nice one for the advise. I was a bit worried about uping the voltage anymore but I've managed to get the cpu temp down to a stable 35c, which...
Sc0rian - Keepin it real Old rad out of a scrapped metro, cheap plastic storage box, fans & tubing are only cheap even on pocket money, guess...
lo all, Some time back I fried my CPU cos I left the standard free HS/fan on it, without any consideration of the consequences...I then thought...
lo all, I've been testing what I can get away without burning my rig out but as I'm a bit new to OCing I'd like some feedback from you guys......
