its also helpful for sedating yourself when your watercooling spills onto your brand new rig.
usually rubbing alcohol or grain alcohol (~190 proof) will remove that crap easily.
well even though i dont like the band...at all, i still think you did a good job on the case. more and better pics are in order :thumb:
thats the first time ive seen that case, and for a second i thought it was someone elses finished mod(they were doing the duct on the bottom). man...
wow and i thought i didnt put enough thought into my mods.... :duh:
ive got a couple batteries i need to charge, and ive got a broken charger. these arent your every day little walkman batteries, these are big fat...
you should have dremeled off the backs of the hubcaps so they wouldnt stick out so far. right now it really looks like youre trying to show off...
have u tried 2-2-2-8? or upping the vdimm voltage to 2.6?
have you tried manually setting the ram in bios? the mobo might think that the ram cant do it w/o you telling it specifically.
the windows you get with that is meant for intel itanium based machines, not athlon64. also, since i have an a64, i tried out the beta and it...
ok well i understand the good ram part lol, its just a little easier on my wallet to get the cheaper. anyways, explain this windows seeing only...
lately ive been doing a lot of cpu and ram intensive stuff like video editing and 3d modelling, and i can see that ill be doing a lot more in the...
ok heres my problem: im big on video editing and 3d modelling. currently, when i try to use 3d studio max, it runs pretty fine for a little...
once you figure it out, youll kick yourself for not getting it sooner. just keep the name of the game in mind....
is it possible that your sata drive isnt plugged in? [IMG]
they require pictures, thus, theres a picture. but i want the admins to get really technical and ban gnome because they said pictures as in plural...
a little photoshop tip: go to file>automate>web photo gallery specify a source and destination folder all your images will be put into a webage...
i just checked that out, i really like that. the adjustable rails and the seperate circuits really impressed me. great price too, 115$ at newegg...
i was thinking of going to sleep(its 2am here) and then i saw the teaser :jawdrop: :jawdrop: :jawdrop: :jawdrop: :jawdrop: . my finger is...
maybe it can survive a /. but this time itll be a /. + all of bit-tech + all of every other modding forum + their brothers, sisters, cousins,...
