It's not that i am in need of a throwline because i am not a kayaking person ... But it is a product with a name like nookie ..., that should...
hehe that's half the fun of driving a diesel ... Start it normally, and as it idles half bad , push the throttle a bit ... as it misfires a...
the way a ferrari is supposed to look
you should look for a matte coating, also i once had a decent effect with glossy coating by just spraying incomplete layers ( the paintdrops...
100 lbs * 4 makes 400lbs (~ 180 kg) a decent 1 person bed( especially adjustable beds) might already make half of that weight, add a heavy...
no, green is only an easy identification for your mouse, PS/2 doesn,t have to be green, But to be honest, S video is more likely and if i can...
Rust ? That is the form iron is found naturally.
well, probably hijacking a tread now but here it goes: Last friday i refueled after the acetone addition, usage has been 6.6 L/100 ( 15,1 km/L...
Sonflower, No problem, that is what i'm using at the moment, Olive oil, try to avoid that, been reading some on that and seems to clog your...
normal diesel is hardly agressive, that's why a lot of older diesel cars have problems with biodiesel, the "vanilla" rubber from the fuel system...
euhm, Biodiesel is refined vegetable oil, it has undergone a treatment comparable with the treatment oil gets to get gasoline andor diesel,...
They do http://users.pandora.be/gits/ea81.html this one is for sale :) TJK, you got PM (sorry for thread revival)
hmm, stay away from the JVC KDG-111, that thing is a hell on scratched CD's , will withstand any bump but is not able to read through the smallest...
you make me laugh china already uses metric
38 cc sounds about right tbh , 38 ci would make it about 620 cc ( 1 ci = 16.4 cc correct me if i'm wrong) and that would make it an extremly...
I hope your car is a diesel, because diesel is cheaper then petrol over here and does more km's per liter, the fuel cost will be half of that a...
a quick google gives me the idea to keep the leap ahead thing, but just attach a subtle picture like this one...
heh, first try didn't seem to be successfull, used my old p1 for testing, wont hurt as mutch when i fry that one, nothing happened, will redo...
tnx, that seems usefull, will try that combi before i mess with anything inside my screen, have a week off between c-mas and newyear, i'll have a...
i haven't gotten around to more than a quick look, the cable goes into some steel cage with PCB in it, how do i discharge the tube itself ......
