I'm pretty sure it is one, even down to the tool-less 5.25" bays. I've seen a lot of cases that look like 690s, I reckon they're being dished out...
Well that's my 2x2TB RAID mirror out of the window. On the plus side, OCZ Vertex 120GB, here I come!
HP PCs are nothing but problems, we get tonnes of them in at work, mostly with board faults and overheating problems.
If they made computers easier to use and harder to break then I'd be out of a job.
Why don't countries spend their parliament time on trying to solve IMPORTANT issues such as war and poverty and not petty intellectual property...
What I mean is I only tested it for about an hour, didn't crash. Idle temp was 44c, temp under load after 10 mins was 63c at highest.
Hey guys, what are your best efforts with a stock cooler? I managed 3.7GHz so far with my Phenom II x4 955 BE, stock voltages, stock FSB,...
Hey chaps. I have just had what I suspect to be a PSU death occur in one of my rigs. Beforehand it was BSODing and saying it was an infinite loop...
Thanks for the help guys, I think I'll stick with the 500w since I'm not planning on running Prime 95 and Furmark at the same time all day long...
If I upgrade my PSU it'll be because I get an absolute monster GPU. I'm not replacing one of the best components that I have ever owned. I'll try...
Hey dudes. I was wondering if I can get two 4850s, Crossfire'd, on my current PSU. It's an OCZ Stealth X Stream 500w, supposedly 80%+. If you look...
Probably my Windows install then. Loads of crap on my HDD at the moment. Slowing it down. My new board might explain the speed increase.
2x2GB DDR3. Also, does 4GB ready boost count? :D
I reckon it's your specs. I had the same issues. I was running a Core 2 Duo with 2GB DDR2 and a 4850 and I recently upgraded to a Phenom II x4 and...
I think there is a tradeoff in this case. They've got proper sci-fi writers in for the story but haven't bothered updating the PC version of the...
I agree, I had an XFX 7900GS for a while, not the best GPU ever but the card itself was extremely well made. Whilst it was indeed noisy, it did...
So much for free and tolerant society. I won't be buying it until it goes down to £15 anyways.
Dodgy RAM has caused BSODs for me before. Memtest usually shows up problems. Post the results for all to see.
I definitely agree on the Antec 300 and i5 750, it's supposed to be a killer overclocker.
Do you use the onboard sound? It's a nightmare in my experience. Drivers suck for onboard imo.
