Just a quick update to say I've decided where to buy the HDD and new DVD drive to make quite a saving. I'll be using a Seagate 5400RPM 2.5" Drive...
:read: :D
Cadbury's Turkish and Irn-Bru :rock:
Draw it. It's 2D
The profile of the shape is basically what it would look like end on. ie Cross-section. In the case of Jazzle's example, the donut shape in the...
Cheers I've sent them a quick E-mail. Most M2 screws are 20mm in length maximum.
Does anyone know where to purchase M2 threaded rod in the UK? The only places I've found are almost always out of stock. Even better would be four...
Yup, a battery life of around three weeks isn't great :) 8x AAA batteries and my new charger should do the trick though :thumb:
I'll let you off :D
Is the top fan intentionally intake?
I would try a slower speed and cut gradually. Plexi will usually melt when drilling/cutting and dry on the bit which makes it even harder to cut...
Hmm... it's a shame they don't do smaller or finer bits. Are you using any lubricant when cutting? I'm going to give that a try next time I use it.
It will probably work. The learning setup on this remote is fantastic. From the setup menu, you select the button you want to learn and then point...
Derelict: The PSU will look even better when it's finished. :) Wrigley1: No comment on the LCD or PSU :) The LCD bezel has a protective sheet...
Outside is just as bad. I can't stand walking down the street behind someone blowing smoke all over the place. The shopping centre where I live...
The reason I bought it was because Maplin sent me out a leaflet with their latest offers and I saw a blue backlit LCD remote. Instead of buying it...
It has one of the largest device databases in it, but it didn't have my DVD player or TV :eyebrow: You use IR learning, and point the original...
It does have buttons. Unlike other remotes, the Kameleon doesn't have a touch screen panel. Have you ever seen inside a calculator? The buttons...
Someone DOESN'T like lemon on their pancakes??? *lights a torch and grabs a pitchfork*
Looks vile... microwave pancakes for me :rock:
