Wow! Really amazing work with this one. Looking forward to following you :-) Good luck with the project!
Hey, Do anyone know a hard drive cage that is easy to put in a scratch build? I'm thinking it should have 3-4 HDD spaces. I don't want it to...
I think the most important way to be safe is to think about your browsing and usage. 1) Don't visit websites that looks creepy (i.e. some...
hamza: The only reason why I chose 8GB of RAM was because it was only about $7 USD more than 4GB :) But yeah, I won't be using it for anything...
Thanks guys! Can this be run passively? Or should I get a small heatsink+fan?
So I'm going for this: Mobo: ASRock FM2A75M-ITX CPU: A10-5800K 4 MB RAM: Crucial 1 x 8 GB 1600MHz DDR3 SSD: Intel 330 60 GB PSU: picoPSU-160-XT...
But I already have a desktop PC. I just want a small one only for running CS 1.6 to bring to LANs etc. So it should be small factor. I have tried...
I've used Intel my entire life, and not really been into AMD. But is AMD really better when it comes to small builds performance-wise? In...
Hey guys I'm looking to build a small PC that should only be capable of running Counter Strike 1.6 with stable 100fps. A passively cooled...
My humble setup :) needs a little cable routing :D [img]
How about disk encryption and RAID 5 with OMV?
Hi there, I'm building a NAS, and need some advice on operating systems. As far as I can tell, the best are FreeNAS and Ubuntu Server....
Hi there, I'm building a mini-ITX nas, and have thought a little about which processor I should use. The new Sandy Bridge Celeron's are...
I don't need a DVD drive, so I'm not using that. However, I thought that if I would extend the rig with watercooling, I could use one of the bays...
Hmm.. I think I'm going for the Lian Li... IF I were to install WC at a later time, I think it could be easier to build into that case, if I...
The SG07 looks pretty interesting, though a bit pricey.... I had looked at Lian Li PC-Q08B, but the SG07 is with a PSU included, so I guess the...
How does a dual slot GPU work with standard cases? Is there any modding required for them to fit?
Thanks for your replies! I'm aware that it could be done cheaper with e.g. MATX, but I really need a portable build. Regarding cooling, I'm...
Mobo: Should I wait for the Z77 ones to come out? (ASUS P8Z77-I DELUXE). Otherwise, I'm thinking of an ZOTAC H61-ITX. CPU: Core i3 I3-2120 3.3 GHz...
Hi everyone, I'm thinking about building a cheap mini itx rig that I can use at LAN parties etc. To keep the price low, I'm thinking of...
